مشکل این کدها چیه؟
mehrdadgh آفلاین
ارسال‌ها: 830
موضوع‌ها: 58
تشکرها : 654
( 1904 تشکر در 596 ارسال )
مشکل این کدها چیه؟
این کد رو برای نمایش دوتا فلش در تابلو نوشتم که با 4 تا کلید که یکیش به وقفه ها وصله کنترل میشه ولی وقتی کلید وقفه رو میزنم که عمل کنه یه بار شروع به عمل مبکنه و بدون توجه به کلیدهای دیگه کارشو تموم میکنه!
$regfile = "m16def.dat"
$crystal = 8000000
Config Portb = Output
Config Porta = Output
Dim Col As Byte
Dim Scan As Byte
Dim Refresh As Byte
Dim Index As Byte
Dim S As Byte
Dim R As Byte
Dim Mask As Byte
Dim A As Byte , X As Byte
Config Int0 = Rising
Enable Interrupts
enable int0
On Int0 Main
Main:
Debounce Pind.0 , 1 , Mehr
Debounce Pind.1 , 1 , Mehr1
Mehr:
Debounce Pind.1 , 1 , Mehr2
Debounce Pind.3 , 1 , High1
Mehr1:
Debounce Pind.0 , 1 , Mehr3
Debounce Pind.3 , 1 , Low1
Mehr2:
Gosub High1
Gosub Low1
Mehr3:
Gosub Low1
Gosub Hogh1
Low1:
For S = 0 To 8
A = 8 - S
Mask = &HFF
Shift Mask , Right , S
For Refresh = 1 To 10
Scan = &B00000001
For Col = 0 To 4
Portb = Lookup(col , Gelayof)
Shift Portb , Left , A
X = Portb Or Mask
Portb = Not X
Porta = Scan
Waitus 250
Rotate Scan , Left
Porta = &H00
Next Col
Next Refresh
Next S
For S = 0 To 8
A = 8 - S
Mask = &HFF
Shift Mask , Left , A
Scan = &B00000001
For Col = 0 To 4
Shift Portb , Right , S
X = Portb Or Mask
Portb = Not X
Porta = Scan
Waitus 250
Rotate Scan , Left
Porta = &H00
Next Col
Next Refresh
Next S
Return
High1:
For S = 0 To 8
A = 8 - S
Mask = &HFF
Shift Mask , Left , S
Scan = &B00000001
For Col = 0 To 4
Portb = Lookup(col , Gelayof1)
Shift Portb , Right , A
X = Portb Or Mask
Portb = Not X
Porta = Scan
Waitus 250
Rotate Scan , Left
Porta = &H00
Next Col
Next Refresh
Next S
For S = 0 To 8
A = 8 - S
Mask = &HFF
Shift Mask , Right , A
Scan = &B00000001
For Col = 0 To 4
Shift Portb , Left , S
X = Portb Or Mask
Portb = Not X
Porta = Scan
Waitus 250
Rotate Scan , Left
Porta = &H00
Next Col
Next Refresh
Next S
Return
Gelayof1:
Data &B11110111
Data &B11101111
Data &B11000000
Data &B11101111
Data &B11110111
Gelayof:
Data &B11110111
Data &B11111011
Data &B10000001
Data &B11111011
Data &B11110111
دستور return رو نمیخام مربوط به وقفه ها باشه بلکه برای gosub نوشتم
به نظرتون مشکل از این میتونه باشه؟
ISAplast.ir
۲۴-اردیبهشت-۱۳۸۸, ۲۲:۱۱:۵۲
1nafar غایب
ارسال‌ها: 1,195
موضوع‌ها: 91
تشکرها : 1577
( 4273 تشکر در 953 ارسال )
RE: مشکل این کدها چیه؟
با زدن کلید به برچسب Main پرش میشه ، مشکل در اتصال دوتا کلید موجود در اونجا هست .شما از مقاومت های pulldown استفاده کردید ؟
۲۸-اردیبهشت-۱۳۸۸, ۰۸:۰۱:۴۹
mehrdadgh آفلاین
ارسال‌ها: 830
موضوع‌ها: 58
تشکرها : 654
آره پول اپ کرده بودم
تو دستور debounce باید پورت d رو هم ورودی تعریف می کردیم قبل از اینکه ازش استفاده کنیم؟
دستور برگشتreturn که هم مربوط به debonuceمیشه و هم به پرش gosub. حالا کدوم رو در نظر میگیره؟ یا هر کدوم که اجرا شد اون رو در نظر میگیره؟ اصلا میشه رای دو تا پرش یه return گذاشت؟
فکر کنم مشکل برنامش باشه
ISAplast.ir
۲۸-اردیبهشت-۱۳۸۸, ۱۱:۰۲:۲۹
1nafar غایب
ارسال‌ها: 1,195
موضوع‌ها: 91
تشکرها : 1577
نقل قول: تو دستور debounce باید پورت d رو هم ورودی تعریف می کردیم قبل از اینکه ازش استفاده کنیم؟
بله باید به عنوان ورودی تعریف بشه
نقل قول: دستور برگشتreturn که هم مربوط به debonuceمیشه و هم به پرش gosub. حالا کدوم رو در نظر میگیره؟ یا هر کدوم که اجرا شد اون رو در نظر میگیره؟ اصلا میشه رای دو تا پرش یه return گذاشت؟
هر کدوم که سریع تر خونده بشه
مشکل از تعریف نکردن ورودی هست
۲۹-اردیبهشت-۱۳۸۸, ۲۰:۰۸:۳۹
تشکر شده توسط : mehrdadgh
mehrdadgh آفلاین
ارسال‌ها: 830
موضوع‌ها: 58
تشکرها : 654
نقل قول: هر کدوم که سریع تر خونده بشه
میخام فقط برای gosub برگشت داشته باشم. ایا راهی هست یا باید برنامه رو تغییر بدم؟
ISAplast.ir
۲۹-اردیبهشت-۱۳۸۸, ۲۰:۲۶:۵۹
