مشکل در اجرای مجدد برنامه
arash67 آفلاین
ارسال‌ها: 151
موضوع‌ها: 53
تشکرها : 43
( 33 تشکر در 23 ارسال )
$regfile "m16def.dat"
$crystal 8000000
Config Portd.0
Output
Config Portd.1
Output
Config Portd.2
Output
Config Pinc.0
Input
Config Pinc.1
Input
Config Pinc.2
Input
Config Pinc.3
Input
Config Pinc.4
Input
Config Pinc.5
Input
Config Pinc.6
Input
Config Pina.0
Input
Starts Alias Pinc.0
Stops Alias Pinc.1
Menu Alias Pinc.2
Incr_b Alias Pinc.3
Decr_b Alias Pinc.4
Swup Alias Pinc.5
Swdown Alias Pinc.6
Jack Alias Portd.0
Role Alias Portd.1
Heater Alias Portd.2
Portd
= &B11111000
Portc
= &B01111111
'////////////////////////////ADC Configuration////////////////////////////
Config Adc = Single , Prescaler = Auto , Reference = Avcc
Stop Adc : Start Adc
////////////////////////////Timer Configuration//////////////////////////
Config Timer0 Timer Prescale 1
Enable Interrupts
Enable Timer0
On Timer0 Total
Timer0
0
Stop Timer0
Start Timer0
'///////////////////////////////Interrupts////////////////////////////////
Config Int0 = Falling
Enable Int0
On Int0 Halt
///////////////////////////////Variables/////////////////////////////////
Dim Jack_delay As Word
Dim Role_delay
As Word
Dim Set_point
As Byte
Dim Quantity
As Word
Dim Temp
As Word
Dim Sum
As Word
Dim Ave
As Single
Dim
Final As Single
Dim Steps
As Byte
Dim Change
As Byte
Dim A
As Byte
Dim B
As Byte
Dim Temp_1
As String 3
Cls : Cursor Off : Delay
Reset Jack : Reset Role : Reset Heater
Home
Lcd "jack= " ; Jack_delay ; "  "
Locate 2 , 1
Lcd "Role= " ; Role_delay ; "  "
Locate 1 , 10
Lcd "No= " ; Quantity ; "   "
Locate 2 , 10
Lcd "Temp= " ; Final ; "  "
      If Starts = 0 And Swup = 0 Then
             Set Jack
             Bitwait Swdown , Reset
             Waitms Jack_delay
             Reset Jack
             Bitwait Swup , Reset
             Set Role
             Waitms Role_delay
             Reset Role
             Decr Quantity
       End If
Loop Until Stops = 0
Total:
Incr Steps
Select Case Steps
Case 1:
Case 2:
Stop Timer0 : Timer0 = 0
Incr Change
Temp = Getadc(0)
Stop Adc : Sum = Sum + Temp
If Change = 100 Then
Ave = Sum / 100
Final = Ave * 2.53
Final = Round(final)
Change = 0
Sum = 0
End If
Start Adc : Start Timer0
Case 3:
Stop Timer0 : Stop Adc : Timer0 = 0
If Menu = 0 Then
Incr A : Waitms 5
      If A = 100 Then
      Cls : Locate 1 , 6 : Lcd "SETTINGS" : Lcd " " : Waitms 300 : Cls
          Home : Lcd "Jack Delay= " ; Jack_delay : Lcd " " : Waitms 300
          If Incr_b = 0 Then : Jack_delay = Jack_delay + 10 : Delay : End If
          If Decr_b = 0 Then : Jack_delay = Jack_delay - 10 : Delay : End If
       Loop Until Menu = 0
       Writeeeprom Jack_delay , 1
       Waitms 35
      Cls
         Home : Lcd "Role Delay= " ; Role_delay : Lcd " " : Waitms 300
         If Incr_b = 0 Then : Role_delay = Role_delay + 10 : Delay : End If
         If Decr_b = 0 Then : Role_delay = Role_delay - 10 : Delay : End If
      Loop Until Menu = 0
      Writeeeprom Role_delay , 2
      Waitms 35
      Cls
         Home : Lcd "Temp= " ; Set_point ; "C'" : Lcd " " : Waitms 300
         If Incr_b = 0 Then : Set_point = Set_point + 10 : Delay : End If
         If Decr_b = 0 Then : Set_point = Set_point - 10 : Delay : End If
      Loop Until Menu = 0
      Writeeeprom Set_point , 3
      Waitms 35
      Cls
         Home : Lcd "
No" ; Quantity ; "   " : Lcd " " : Waitms 300
         If Incr_b = 0 Then : Quantity = Quantity + 5 : Delay : End If
         If Decr_b = 0 Then : Quantity = Quantity - 5 : Delay : End If
      Loop Until Menu = 0
      Writeeeprom Quantity , 4
      Waitms 35
      A = 0
      End If
      Else
      A = 0
      End If
      Steps = 0
      Start Timer0 : Start Adc
End Select
Return
Halt:
Reset Jack
Reset Role
Reset Heater
Return
آنقدر شکست خوردم تا راه شکست دادن را یاد گرفتم .(ناپلئون بنا پارت).
اینم وبلاگ من: WWW.TELECOM89.BLOGFA.COM
۱۹-اسفند-۱۳۹۰, ۱۲:۱۲:۴۰
arash67 آفلاین
ارسال‌ها: 151
موضوع‌ها: 53
تشکرها : 43
RE: مشکل در اجرای مجدد برنامه
با سلام برنامه بالا زمانی که برنامه در حلقه اصلی در حال اجراست وقتی به bitwait میرسه منتظره میشه پایه ورودی مورد نظر ریست بشه ولی در این زمان وقتی وقفه0 اجرا میشه برنامه به حالت stop کامل در میاد اما ولی برای شروع مجدد باید حتما پایه مورد نظر ریست شده باشه .
دلیلش چیه؟
۱۹-اسفند-۱۳۹۰, ۱۳:۲۲:۴۳
( 8172 تشکر در 2772 ارسال )
منظورتون از استاپ كامل چيه ؟
وقتي روي خط bitwait مي رهه به وقفه و برمي گردهه ، بايد روي خط bitwait دوبارهه برگردهه ، درسته ؟
اين اتفاق نمي يفته ؟
۱۹-اسفند-۱۳۹۰, ۱۷:۰۶:۴۹
arash67 آفلاین
ارسال‌ها: 151
موضوع‌ها: 53
تشکرها : 43
myBB  RE: مشکل در اجرای مجدد برنامه
سیکل کاری برنامه به این صورت که اگر Sw-up وصل باشه و دکمه استارت فشرده شده باشه جک فعال شده تا زمانی که SW-down وصل بشه یه مدت زمانی صبر میکه
و جک غیر فعال شده و تازمانی که SW-up وصل بشه در این زمان Role فعال شده وسپس غیر فعال میشود و دوباره همین سیکل تکرار میشود. در صورتی که در هر مرحله از سیکل برنامه دکمه STOP فشرده بشه برنامه متوقف شده و برای شروع مجدد باید تو اون مرحله مربوط به bitwait فعال بشه تا اجرا برنامه امکان پذیر باشه ، من میخوام زمانی که کلید استاپ فشرده میشه بتونم برنامه رو دوباره از اول اجرا کنم.
AngryAngryAngryAngryAngryAngryAngryAngryAngryAngryAngryAngryAngryAngry
[attachment=7169]
۱۹-اسفند-۱۳۹۰, ۱۸:۴۴:۵۴
مهندس دقيقا متوجه توضيحاتت نمي شم و برنامه ات رو هم نمي تونم خط به خط بخونم ...
دقيقا جايي رو كه مشكل داري رو گويا توضيح بدهه ! فرايند كل برنامه رو نمي خواد بگي .
مثلا : شما مي خواي برنامه در اون قسمت خاص ، اين جور اجرا بشه ، اما برنامه فلان جور اجرا مي شه ...
۱۹-اسفند-۱۳۹۰, ۲۱:۵۲:۱۵
arash67 آفلاین
ارسال‌ها: 151
موضوع‌ها: 53
تشکرها : 43
وقتی برنامه به این قسمت میرسه Bitwait Swdown , Reset و من میخوام دستگاه به هر دلیلی متوقفش کنم وقفه مربوط به INT0 رو اجرا میکنم خروجی ها همه ریست شده و وقتی که دوباره دکمه start میزنم طبیعتا باید خروجی jack فعال بشه اما برنامه تو این قسمت منتظر Bitwait Swdwon ,resetمیشه من میخوام زمانی که این اتفاق میفته بتونم استارت کنم.
اون برنامه خودمو یک بار اجرا کن زمانی که SW-up وصل Start بزن بعدش دکمه Stop بزن حالا دوباره دکمه Start بزن متوجه میشی که خروجی جک فعال نمیشه .البته قبلش باید دکمه منو رو برای 5 ثانیه نگهداری تا وارد تنظیمات بشی برای وارد شدن به هر مرحله همون دکمه menu رو بزن بعدش برنامه رو اجرا کن.
امیدوارم منظورمو متوجه شده باشی.
(آخرین ویرایش در این ارسال: ۱۹-اسفند-۱۳۹۰, ۲۳:۳۵:۲۴، توسط arash67.)
۱۹-اسفند-۱۳۹۰, ۲۳:۲۵:۵۱
نقل قول: وقتی برنامه به این قسمت میرسه Bitwait Swdown , Reset و من میخوام دستگاه به هر دلیلی متوقفش کنم وقفه مربوط به INT0 رو اجرا میکنم خروجی ها همه ریست شده و وقتی که دوباره دکمه start میزنم طبیعتا باید خروجی jack فعال بشه اما برنامه تو این قسمت منتظر Bitwait Swdwon ,resetمیشه من میخوام زمانی که این اتفاق میفته بتونم استارت کنم.
آهان ... ، خوب توي اولين پستم هم همين رو پرسيدهه بودم ديگه ... !
همون موقع مي گفتي آرهه ، انقدر انرژي تلف نمي كرديم Biggrin
خوب طبيعيه ديگه ... ، وقتي روي bitwait برهه به وقفه ، موقع برگشت هم رو bitwait بر مي گردهه ، در نتيجه تا شرط bitwait رو برآوردهه نكني ، روي همون bitwait برنامه ات مي مونه ...
بايد يه جور ديگه كد بزني ...
مي توني بجاي bitwait يه حلقه ي بينهايت بذاري كه توش يه شرطي رو check مي كني ، توي وقفه هم يه متغيير رو مقدار دهي كني كه موقع برگشت شرط رو در حلقه ي بينهايت برآوردهه كنه و از حلقه در بياد .
اينطوري برنامه ات متوقف نمي شه ...
۲۰-اسفند-۱۳۹۰, ۰۰:۰۷:۲۶
تشکر شده توسط : arash67
arash67 آفلاین
ارسال‌ها: 151
موضوع‌ها: 53
تشکرها : 43
شرمنده مهندس
میشه همین برنامه منو به روشی که خودت میگی edit کنی دمت گرم.
۲۰-اسفند-۱۳۹۰, ۰۰:۳۸:۳۵
نه ، نمي شه ... :d
يه مثال حدودي مي زنم ، مي توني ازش استفاده كني ...
در واقع حلقه ي do-loop مي تونه جاي bitwait استفاده بشه ...
label?:
m=0
do
if m=1 then
exit do
يا
goto label?
end if
loop
زير روال وقفه:
Iint0:
if m=0 then
m=1
end if
return
۲۰-اسفند-۱۳۹۰, ۱۹:۴۶:۰۳
arash67 آفلاین
ارسال‌ها: 151
موضوع‌ها: 53
تشکرها : 43
دستت درد نکنه دادا
راستی یه سوال آیا lM335 تحمل دمای بالا 100 درجه در تماس مستقیم با حرارت مثلا در تماس با هیتر داره ؟
۲۰-اسفند-۱۳۹۰, ۲۲:۱۶:۴۶
خواهش مي شه...
ديتاشيت بخون ، توضيح داده ...
مورد ديگه اينكه چون اين سنسورها همه ي مداراتشون يجا هست ، معمولا اينطوري ازشون استفادهه نمي كنن ...
براي دماهاي بالا تراشه ها انتخاب مناسبي نيستن.
در تماس مستقيم هم سنسور رو در يه پوشش محافظ قرار مي دن ، البته باعث مي شه حساسيتش كمتر بشه (نسبت به دماي محيط)
۲۱-اسفند-۱۳۹۰, ۱۳:۲۰:۳۵
آخرین ارسال: fedagh
  مشکل در هنگام بوت شدن ویندوز و اجرای دستورات میکرو unforgiven 3 3,732 ۳۱-مرداد-۱۳۹۵, ۱۹:۴۷:۲۵
آخرین ارسال: unforgiven
  مشکل در برنامه code vision 3.12 ali74342 10 7,232 ۲۲-مرداد-۱۳۹۵, ۰۰:۱۶:۰۷
آخرین ارسال: shima.rrr
Sad مشکل عجیب در برنامه اندازه گیری دما و سنجش زمان ! MicrowaveCO 2 2,762 ۱۴-خرداد-۱۳۹۴, ۱۸:۳۱:۳۲
آخرین ارسال: MicrowaveCO
Question مشکل در برنامه ی تایپ با کیپد 4×4 salehjg 4 7,249 ۲۵-اردیبهشت-۱۳۹۴, ۱۸:۲۵:۰۳
آخرین ارسال: z20
  [فوری] مشکل با برنامه کانتر میکرو milad15m 22 9,050 ۱۲-مهر-۱۳۹۳, ۱۷:۲۸:۰۸
  مشکل عجیب با برنامه بسکام دراکولا 7 9,727 ۱۹-اردیبهشت-۱۳۹۳, ۲۲:۰۳:۵۶
آخرین ارسال: avr65
