ایجاد zone فایل برای bind
همونطور که میدونید BIND مشهور ترین سرویس DNS تحت لینوکس هست!
توس این برنامه میتونید یک zone برای سایتتون بسازید و از کلی زحمت راحت بشن:
کد: (نام فایل mkzone.sh)
#!/bin/bash
# A Bash shell script to create BIND ZONE FILE.
# Tested under BIND 8.x / 9.x, RHEL, DEBIAN, Fedora Linux.
# Copyright (c) 2002,2009 Vivek Gite <vivek@nixcraft.com>
# This script is licensed under GNU GPL version 2.0 or above
# This script is part of nixCraft shell script collection (NSSC)
# Visit http://bash.cyberciti.biz/ for more information.
# Examples:
# ./mkzone.sh example.com default-www-IP-address
# ./mkzone.sh cyberciti.biz 74.12.5.1
# Last updated on: Mar/24/2007 - Fixed a few bugs.
DOMAIN="$1"
WWWIP="$2"
if [ $# -le 1 ]
then
echo "Syntax: $(basename $0) domainname www.domain.ip.address [profile]"
echo "$(basename $0) example.com 1.2.3.4"
exit 1
fi
# get profile
PROFILE="ns.profile.nixcraft.net"
"$3" != "" ] && PROFILE="$3"
SERIAL=$(date +"%Y%m%d")01 # Serial yyyymmddnn
# load profile
source "$PROFILE"
# set default ns1
NS1=${NAMESERVERS[0]}
###### start SOA ######
echo "\$ORIGIN ${DOMAIN}."
echo "\$TTL ${TTL}"
echo "@ IN SOA ${NS1} ${EMAILID}("
echo ${SERIAL} ; Serial yyyymmddnn"
echo ${REFRESH} ; Refresh After 3 hours"
echo ${RETRY} ; Retry Retry after 1 hour"
echo ${EXPIER} ; Expire after 1 week"
echo ${MAXNEGTIVE}) ; Minimum negative caching of 1 hour"
echo ""
###### start Name servers #######
# Get length of an array
tLen=${#NAMESERVERS[@]}
# use for loop read all nameservers
echo "; Name servers for $DOMAIN"
for (( i=0i<${tLen}; i++ ));
do
echo
"@ ${ATTL} IN NS ${NAMESERVERS[$i]}"
done
###### start MX section #######
# get length of an array
tmLen=${#MAILSERVERS[@]}
# use for loop read all mailservers
echo "; MX Records"
for (( i=0i<${tmLen}; i++ ));
do
echo
"@ ${ATTL} IN MX $(( 10*${i} + 10 )) ${MAILSERVERS[$i]}"
done
###### start A pointers #######
# A Records - Default IP for domain
echo '; A Records'
echo "@ ${ATTL} IN A ${WWWIP}"
# Default Nameserver IPs
ttLen=${#NAMESERVERSIP[@]}
# make sure both nameserver and their IP match
if [ $tLen -eq $ttLen ]
then
# use for loop read all nameservers IPs
for (( i=0i<${ttLen}; i++ ));
do
thisNs="$(echo ${NAMESERVERS[$i]} | cut -d'.' -f1)"
echo "${thisNs} ${ATTL} IN A ${NAMESERVERSIP[$i]}"
done
else
# if we are here means, our nameserver IPs are defined else where else... do nothing
fi
echo "; CNAME Records"
echo "www ${ATTL} IN CNAME @"
فایل تنظیماتش: (با نام ns.profile.nixcraft.net )
# defaults profile for nameserver ns1.nixcraft.net
TTL="3h" # Default TTL
ATTL="3600"    # Default TTL for each DNS rec
EMAILID="vivek.nixcraft.in." # hostmaster email
REFRESH="3h" # Refresh After 3 hours
RETRY="1h" # Retry Retry after 1 hour
EXPIER="1w"    # Expire after 1 week
MAXNEGTIVE="1h"    # Minimum negative caching of 1 hour
    # name server names FQDN
NAMESERVERS=("ns1.nixcraft.net." "ns2.nixcraft.net." "ns3.nixcraft.net.")
# name server IPs,
    # leave it blank if you don't need them as follows
NAMESERVERSIP=()
#NAMESERVERSIP=("202.54.1.10" "203.54.1.10" "204.54.1.40")
    # mail server names
MAILSERVERS=("mail.nixcraft.net.")
#MAILSERVERS=("smtp1.nixcraft.net." "smtp2.nixcraft.net.")
    ################# add your own A recored here ##########################
    # You can add additonal A recs using following function
function LoadCutomeARecords(){
    echo >/
dev/null # keep this line
    # Uncomment or add A recoreds as per your requirments
    # echo "ftp $ATTL IN A 202.54.2.2"
    # echo "webmail $ATTL IN A 202.54.2.5"
    # echo "ipv6host $ATTL IN AAAA 2001:470:1f0e:c2::1"
مثال:
# ./mkzone.sh cyberciti.com 202.54.1.2 ns.profile.nixcraft.net
خروجی
$ORIGIN cyberciti.com.
$TTL 3h
@    IN    SOA    ns1.nixcraft.net.    vivek.nixcraft.in.(
            2009032401    ; Serial yyyymmddnn
            3h        ; Refresh After 3 hours
            1h        ; Retry Retry after 1 hour
            1w        ; Expire after 1 week
            1h)        ; Minimum negative caching of 1 hour
; Name servers for cyberciti.com
@            3600    IN    NS    ns1.nixcraft.net.
@            3600    IN    NS    ns2.nixcraft.net.
@            3600    IN    NS    ns3.nixcraft.net.
; MX Records
@            3600    IN     MX    10    mail.nixcraft.net.
; A Records
@             3600    IN     A    202.54.1.2
; CNAME Records
www            3600    IN    CNAME    @
وبعد این فایل رو باید به bind معرفی کنید! همین!!!!!!!
زنده باد لینوکس Heart Biggrin
منبع
(آخرین ویرایش در این ارسال: ۲۵-اردیبهشت-۱۳۹۲, ۲۱:۰۳:۵۱، توسط babyy.)
۲۵-اردیبهشت-۱۳۹۲, ۲۱:۰۳:۲۳
تشکر شده توسط : hadikh73, omid_phoenix, lord_viper, Ambassador
