ide and debug
mohamadpk آفلاین
ارسال‌ها: 337
موضوع‌ها: 39
تشکرها : 726
( 661 تشکر در 257 ارسال )
ide and debug
آقایون خسته نباشید .دوستان برای php آیا یک ide خوب که بتونه مثل محیط .net که برای aspx هست دستورات php شما رو در زمان اجرا دیباگ کنید. یعنی خط به خط جلو برید و مقدار داخل متغیر هاتون رو ببینید؟ یک ابزاری تو ویژال استدیو 6 هست که میشه صفحات وب رو دیباگ کرد که خیلی جالب هست آیا از اون می شه در php استفاده کرد. ممنون عزیزان. موفق باشید.
۳۰-بهمن-۱۳۸۸, ۱۱:۴۸:۱۲
__Genius__ آفلاین
ارسال‌ها: 34
موضوع‌ها: 5
تشکرها : 47
( 105 تشکر در 32 ارسال )
RE: ide and debug
سلام .
PHP Designer 2010Professional v7.0.0
[تصویر:  86q7hgp.jpg]
PHP Designer 2008 Professional is a powerful PHP IDE (Integrated Development Environment) / PHP editor for both beginners and professional developers that enhances the process of editing, analyzing and publishing applications and websites powered by PHP and other web languages.
Designed to boost your productivity and simplify complex coding projects through intelligent set of editing tools that includes full support for PHP 5.2, work with any PHP framework, syntax highlighters, intelligent nested code completion and code tip that are displayed as you type, so you do not need to look into documentation to see classes and function attributes, project manager, code snippets, the large built-in code-libraries, highlights (un)matching brackets and tags and numerous tools and wizards to speed of your development.
The strength in PHP lies in the ability to embed it into- and together with other web-languages and technologies. Therefore, does phpDesigner 2007 Professional not only support PHP but also other web-languages as HTML, MySQL, XML, CSS, javascirpt, VBScript, Java, C#, Perl, Python and Ruby!
Support for WAMP/LAMP and AJAX developers through the intelligent syntax highlighting that automatically switches between syntax highlighters for PHP, HTML, CSS, and javascirpt dependant on your position in the document and dims the rest of the code.
Get detailed information about more than 3000 native PHP functions on the fly makes the learning curve for PHP as easy and short as possible.
Jump to any declarations declared in both file and project files with filtering by classes, interfaces, functions, variables and constants.
Easily document your code with phpDocumentor, the standard documentation tool for the PHP language with the built-in phpDocumentor Wizard.
The philosophy behind is to make it, enjoyable to use for hours and hours for both beginners and professional developers through an easy-to-use-, intuitive-, customizable- and tabbed interface!
http://hotfile.com/dl/28287451/a9a4f9a/PHP20Designer20v7.1.0.31.rar.html
۳۰-بهمن-۱۳۸۸, ۱۴:۱۱:۴۲
تشکر شده توسط : mohamadpk, ajlajlajl, alaska
mohamadpk آفلاین
ارسال‌ها: 337
موضوع‌ها: 39
تشکرها : 726
RE: ide and debug
آقا مرسی برم دانلود کنم ببینم چی هست دستت درد نکنه.
آقا مرسی ولی جد عزیزم آمد جلو چشام تا دانلودش کردم فیلتر بود هیچی free download هم بسته بود . اگر کسی می خواد دانلود کنه این لینکه مستقیم
http://dh.hfplg.com/files/79.127.11.217_...1.0.31.rar
(آخرین ویرایش در این ارسال: ۳۰-بهمن-۱۳۸۸, ۱۵:۰۳:۳۰، توسط mohamadpk.)
۳۰-بهمن-۱۳۸۸, ۱۴:۴۲:۴۳
تشکر شده توسط : alaska
