- 1 رأی - میانگین امتیازات: 5
- 1
- 2
- 3
- 4
- 5
project of FPGA calculator
نویسنده |
پیام |
86kourosh
ارسالها: 3
موضوعها: 1
تاریخ عضویت: بهمن ۱۳۸۹
man ye proje peida kardam az internet dar morede mashin hesabe sade hast. mikhastam age momkene ye tozihe koli dar morede in kodha behem bedin va aya in kodha amale shift ro anjam midan???man niaz be ye projeye fpga daram ke ye mahsin hesabe sade bashe va amaliate zarb jam tafrig tagsim and or not va shift right ve shift left dashte bashe aya mitunin komakam konin?ye barname peida kardam ba tagirat ruye in mishe?che tagirati?kesi age mitune lotfan komakam kone forsate ziadi nadaram.mamnun
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity calc1 is
Port ( Clk : in std_logic;
Switches : in std_logic_vector(7 downto 0);
Buttons : in std_logic_vector(6 downto 0);
Result : out std_logic_vector(7 downto 0));
end calc1;
architecture Behavioral of calc1 is
Signal Q0,Q1,Q2,Q3: std_logic_vector(7 downto 0) := (others=>'0');
Signal S: std_logic_vector(1 downto 0);
Signal S3S2S1S0: std_logic_vector(3 downto 0);
Signal D,B,T: std_logic_vector(7 downto 0);
signal Old_buttons: std_logic_vector(6 downto 0);
begin
T <= Switches;
B <= (others=>'0');
Result <= Q0;
One_puls_detector:
process( clk)
variable One_pulses: std_logic_vector(6 downto 0);
begin
if rising_edge( Clk) then
Old_buttons <= Buttons;
One_pulses := not Old_buttons and Buttons;
case One_pulses is
when "0000001" => S <= "01"; S3S2S1S0 <= "0000"; -- Enter
when "0000010" => S <= "10"; S3S2S1S0 <= "0000"; -- Pop
when "0000100" => S <= "11"; S3S2S1S0 <= "0001"; -- +
when "0001000" => S <= "11"; S3S2S1S0 <= "0010"; -- -
when "0010000" => S <= "11"; S3S2S1S0 <= "0100"; -- *
when "0100000" => S <= "11"; S3S2S1S0 <= "1000"; -- /
when "1000000" => S <= "11"; S3S2S1S0 <= "1111"; -- XOR
when others => S <= "00"; S3S2S1S0 <= "0000"; -- nop
end case;
end if;
end process;
The_RPN_Stack:
process( Clk)
begin
case S is
When "00" => Null;
When "01" => Q3<=Q2; Q2<=Q1; Q1<=Q0; Q0<=T;
When "10" => Q0<=Q1; Q1<=Q2; Q2<=Q3; Q3<=B;
When "11" => Q0<=D; Q1<=Q2; Q2<=Q3; Q3<=B;
When others => Null;
end case;
end if;
end process;
ALU_process:
process( S3S2S1S0, Q1, Q0)
begin
case S3S2S1S0 is
when "0001" => D <= Q1+Q0;
when "0010" => D <= Q1-Q0;
when "0100" => D <= Q1(3 downto 0) * Q0(3 downto 0);
-- When "1000" => D <= Q1/Q0; -- This one tricky - make a ROM
when "1111" => D <= Q1 xor Q0;
when others => D <= (others=>'0');
end case;
end process;
end Behavioral;
Added after 6 minutes:
could anyone explain about this code since this program is about RPN calculator which i;m not familiar with
library IEEE;
entity calc1 is
end calc1;
begin
T <= Switches;
B <= (others=>'0');
Result <= Q0;
One_puls_detector:
process( clk)
begin
case One_pulses is
end case;
end if;
end process;
The_RPN_Stack:
process( Clk)
begin
case S is
When "00" => Null;
end case;
end if;
end process;
ALU_process:
begin
case S3S2S1S0 is
end case;
end process;
end Behavioral;
(آخرین ویرایش در این ارسال: ۰۳-بهمن-۱۳۸۹, ۱۷:۳۹:۲۳، توسط 86kourosh.)
۰۳-بهمن-۱۳۸۹, ۱۷:۳۶:۴۲ |
86kourosh
ارسالها: 3
موضوعها: 1
RE: project of FPGA calculator
من يه پروژه از اينترنت پيدا کردم در مورد ماشين حساب. کدهاشونو براتون مي زارم. من نياز دارم به يه پروژه ماشين حساب ک عمليات ساده رو انجام بده و همچنين عمليات logic & shift right , shift left که از keyboard اعداد وارد شه. با انجام چه تغييراتي رو اين کدها مي تونم به چيزي که مي خوام برسم. ممنون مي شم اگه کمکم کنيد و وقت زياديم ندارم. مرسي
يه سري کد هم پيدا کردم که فکر کنم اين بهتره ولي عمليات logic & shift رو نداره.مي شه کمکم کنيد که اين عمليات رو هم توش جا بدم
library IEEE;
entity calculator is
port(A,B : in integer range 0 to 7;
clk : in bit;
sel : in std_logic_vector(1 downto 0);
Q : out bit_vector(6 downto 0);
An : out bit_vector(3 downto 0));
end calculator;
architecture Behavioral of calculator is
signal sub : integer range 0 to 7;
signal sum : integer range 0 to 14;
signal div : integer range 0 to 7;
signal Mul : integer range 0 to 49;
signal Qsub,Qsum1,Qsum2,Qmul,Qmul2,Qdiv :bit_vector(6 downto 0);
signal minus : bit_vector(6 downto 0);
signal divRemainder:bit_vector(6 downto 0);
signal B1:bit_vector(6 downto 0);
signal clk1: bit;
begin
clkDiv : process
variable count :integer range 0 to 50000000;
begin
wait until clk'event and clk='1';
count := count + 1;
if (count = 50000000) then
count := 0;
elsif (count < 25000000) then
clk1 <= '0';
elsif (count > 25000000) then
clk1 <= '1';
end if;
end process clkDiv;
sub_opration : process(A,B)
begin
if(A>B) then
sub<=A-B;
minus<="1111111";
case sub is
when 0 =>Qsub <="1000000";
when 1 =>Qsub<="1111001";
when 2 =>Qsub<="0100100";
when 3 =>Qsub<="0110000";
when 4 =>Qsub<="0011001";
when 5 =>Qsub<="0010010";
when 6 =>Qsub<="0000010";
when 7 =>Qsub<="1011000";
when others => null;
end case;
else
sub<=B-A;
minus<="0111111";
case sub is
when 0 =>Qsub<="1000000";
end case;
end if;
end process sub_opration;
sum_opration : process(A,B)
begin
sum<=A+B;
case sum is
when 0 =>Qsum1<="1000000";
Qsum2<="1111111";
when 1 =>Qsum1<="1111001";
Qsum2<="1111111";
when 2 =>Qsum1<="0100100";
Qsum2<="1111111";
when 3 =>Qsum1<="0110000";
Qsum2<="1111111";
when 4 =>Qsum1<="0011001";
Qsum2<="1111111";
when 5 =>Qsum1<="0010010";
Qsum2<="1111111";
when 6 =>Qsum1<="0000010";
Qsum2<="1111111";
when 7 =>Qsum1<="1011000";
Qsum2<="1111111";
when 8 =>Qsum1<="0000000";
Qsum2<="1111111";
when 9 =>Qsum1<="0010000";
Qsum2<="1111111";
when 10=>Qsum1<="1000000";
Qsum2<="1111001";
when 11=>Qsum1<="1111001";
Qsum2<="1111001";
when 12=>Qsum1<="0100100";
Qsum2<="1111001";
when 13=>Qsum1<="0110000";
Qsum2<="1111001";
when 14=>Qsum1<="0011001";
Qsum2<="1111001";
end case;
end process sum_opration;
Mul_operation : process(A,B)
variable Remm10:integer range 0 to 9;
variable C1: integer range 1 to 7 :=7;
begin
Mul<= A*B;
if(Mul<10) then
case Mul is
when 0 =>Qmul<="1000000";
Qmul2<="1111111";
when 1 =>Qmul<="1111001";
Qmul2<="1111111";
when 2 =>Qmul<="0100100";
Qmul2<="1111111";
when 3 =>Qmul<="0110000";
Qmul2<="1111111";
when 4 =>Qmul<="0011001";
Qmul2<="1111111";
when 5 =>Qmul<="0010010";
Qmul2<="1111111";
when 6 =>Qmul<="0000010";
Qmul2<="1111111";
when 7 =>Qmul<="1011000";
Qmul2<="1111111";
when 8 =>Qmul<="0000000";
Qmul2<="1111001";
when 9 =>Qmul<="0010000";
Qmul2<="1111111";
end case;
else
for j in 7 downto 1 loop
if(10*C1<Mul or 10*C1= Mul)then
Mul<=10*C1;
Remm10:=10*C1-Mul;
end if;
C1:=C1-1;
end loop;
case Mul is
when 0 =>Qmul2<="1000000";
when 1 =>Qmul2<="1111001";
when 2 =>Qmul2<="0100100";
when 3 =>Qmul2<="0110000";
when 4 =>Qmul2<="0011001";
when 5 =>Qmul2<="0010010";
when 6 =>Qmul2<="0000010";
when 7 =>Qmul2<="1011000";
when 8 =>Qmul2<="0000000";
when 9 =>Qmul2<="0010000";
end case;
case Remm10 is
end case;
end if;
end process Mul_operation;
div_operation: process(A,B)
variable C : integer range 1 to 7 :=7;
variable Remm:integer range 0 to 9;
begin
for I in 7 downto 1 loop
if(A=B)then
div<=1;
Remm:=0;
elsif(B>A)then
div<=0;
elsif(A>B)then
if(B*C<A)then
div<=B*C;
Remm:=B*C-A; --the result will display as: div _| Remainder _| B
end if;
C:=C-1;
end if;
end loop;
case div is
when 0 =>Qdiv<="1000000";
when 1 =>Qdiv<="1111001";
when 2 =>Qdiv<="0100100";
when 3 =>Qdiv<="0110000";
when 4 =>Qdiv<="0011001";
when 5 =>Qdiv<="0010010";
when 6 =>Qdiv<="0000010";
when 7 =>Qdiv<="1011000";
end case;
case Remm is
when 0 =>divRemainder<="1000000";
when 1 =>divRemainder<="1111001";
when 2 =>divRemainder<="0100100";
when 3 =>divRemainder<="0110000";
when 4 =>divRemainder<="0011001";
when 5 =>divRemainder<="0010010";
when 6 =>divRemainder<="0000010";
when 7 =>divRemainder<="1011000";
end case;
case B is
when 0 =>B1<="1000000";
when 1 =>B1<="1111001";
when 2 =>B1<="0100100";
when 3 =>B1<="0110000";
when 4 =>B1<="0011001";
when 5 =>B1<="0010010";
when 6 =>B1<="0000010";
when 7 =>B1<="1011000";
end case;
end process div_operation;
choice : process(clk1,sel)
variable m : integer range 0 to 3 := 0;
begin
if(clk1'event and clk1 = '1') then
case m is
when 0 =>
if(sel = "00") then
Q <= Qsub;
elsif(sel="01") then
Q<=Qsum1;
elsif(sel="10") then
Q<=Qmul;
elsif(sel="11") then
Q<=B1;
end if;
An<="1110";
when 1 =>
if(sel = "00") then
Q <= minus;
Q<=Qsum2;
Q<=Qmul2;
Q<="1110011"; -- display _|
end if;
An<="1101";
when 2 =>
if(sel="11") then
Q<= divRemainder;
end if;
An<="1011";
when 3 =>
if (sel="11") then
Q<= Qdiv;
end if;
An<="0111";
end case;
m := m + 1;
end if;
end process choice;
end Behavioral;
(آخرین ویرایش در این ارسال: ۰۳-بهمن-۱۳۸۹, ۲۳:۴۷:۳۱، توسط 86kourosh.)
۰۳-بهمن-۱۳۸۹, ۲۳:۰۰:۴۳ |
86kourosh
ارسالها: 3
موضوعها: 1
باز يه سري کد جديد پيدا کردم مي شه فرق اين رو با قبليه بگين؟
--- Code for LSU EE 4702 Spring 2001
--- Calculator Example
library ieee;
use ieee.std_logic_1164.all;
library Std_DevelopersKit;
use Std_DevelopersKit.Std_Regpak.all;
--- Definitions used by calculator code and testbench.
package calc_defs is
type key_t is array ( 5 downto 0 ) of std_logic;
-- These must be initialized by string literals to be used in a case stmt.
constant key_none : key_t := o"00";
constant key_never : key_t := o"01";
constant key_plus : key_t := o"10";
constant key_minus : key_t := o"11";
constant key_times : key_t := o"12";
constant key_divide : key_t := o"13";
constant key_equal : key_t := o"14";
constant key_clear : key_t := o"15";
constant key_0 : key_t := o"20";
constant key_1 : key_t := o"21";
constant key_2 : key_t := o"22";
constant key_3 : key_t := o"23";
constant key_4 : key_t := o"24";
constant key_5 : key_t := o"25";
constant key_6 : key_t := o"26";
constant key_7 : key_t := o"27";
constant key_8 : key_t := o"30";
constant key_9 : key_t := o"31";
end calc_defs;
--- Calculator
library ieee;
use work.calc_defs.all;
entity calc is
generic( precision: integer := 32 );
port( display_val : out std_logic_vector ( precision-1 downto 0 );
beep : out std_logic;
key_code : in key_t;
reset : in std_logic;
clk : in std_logic);
end calc;
architecture a1 of calc is
-- Internally used constants for categorizing keys.
constant kty_digit: key_t := o"40";
constant kty_arith: key_t := o"41";
-- Other constants.
constant buffer_max:integer := ( 2 ** precision ) - 1;
constant zero: std_logic_vector ( precision-1 downto 0 ) := ( others => '0' );
type state_t is (st_0N, st_0P, st_0C, st_1N, st_1P);
signal beep_time : std_logic_vector ( 5 downto 0 );
signal beep_ack, beep_req : std_logic;
signal pending_op : key_t;
signal state : state_t;
signal cbuffer, acc : std_logic_vector ( precision-1 downto 0 );
impure function do_op return std_logic_vector is
begin
case pending_op is
when key_plus => return acc + cbuffer;
when key_minus => return acc - cbuffer;
when key_times => return acc * cbuffer;
when key_divide =>
if cbuffer = zero then return zero; else return acc / cbuffer; end if;
when others =>
assert false
report "Error in behavioral description."
severity failure;
return zero; -- Pacify compiler.
end case;
end function;
procedure fatal (constant message:in string) is
begin
report "Error in behavioral description: " & message;
assert false
report "Execution stopping."
severity failure;
end procedure;
-- Set a std_logic_vector signal to zero.
procedure clr (signal a :inout std_logic_vector) is
begin for i in a'range loop a(i) <= '0'; end loop; end;
-- Set a std_logic_vector signal to an integer.
procedure set(signal a: inout std_logic_vector; constant i: in integer) is
begin a <= to_stdlogicvector(i,a'length); end;
begin
display_val <= cbuffer;
-- Turn beep on when command by other process and off when timer
-- reaches zero.
process
begin
wait until falling_edge(clk);
if reset = '1' then
beep_ack <= '0'; beep <= '0'; clr(beep_time);
elsif ( beep_ack xor beep_req ) = '1' then
beep_ack <= not beep_ack; set(beep_time,20); beep <= '1';
else
if beep_time /= zero
then beep_time <= beep_time - 1;
else beep <= '0'; end if;
end if;
end process;
process
variable nl: std_logic;
variable key_type: key_t; -- Key category.
-- Note: next_state a variable because signals updated at end of time step.
variable next_state: state_t;
procedure add_digit is
begin
if cbuffer < buffer_max then
cbuffer <= cbuffer * 10
+ std_logic_vector(key_code) - std_logic_vector(key_0);
end if;
end procedure;
procedure do_beep is
begin
beep_req <= not beep_req;
next_state := state;
end procedure;
procedure do_clear is
begin
clr(acc); clr(cbuffer); next_state := st_0N;
end procedure;
begin
wait until rising_edge(clk);
if reset = '1' then
beep_req <= '0';
nl := '0';
state <= st_0N;
clr(cbuffer);
clr(acc);
pending_op <= key_never;
elsif key_code = key_none then
nl := '1';
elsif nl = '1' then
nl := '0';
case key_code is
when key_0 | key_1 | key_2 | key_3 | key_4
| key_5 | key_6 | key_7 | key_8 | key_9 =>
key_type := kty_digit;
when key_plus | key_minus | key_times | key_divide =>
key_type := kty_arith;
when others =>
key_type := key_code;
end case ;
case state is
when st_0N =>
case key_type is
when kty_digit => add_digit; next_state := st_0P;
when key_clear => do_clear;
when others => do_beep;
end case;
when st_0P =>
case key_type is
when kty_digit => add_digit; next_state := state;
when kty_arith => pending_op <= key_code;
acc <= cbuffer;
clr(cbuffer);
next_state := st_1N;
end case;
when st_0C =>
case key_type is
when kty_digit => clr(cbuffer);
wait for 0 ns;
add_digit;
acc <= cbuffer;
clr(cbuffer);
end case;
when st_1N =>
case key_type is
when kty_digit => add_digit; next_state := st_1P;
end case;
when st_1P =>
case key_type is
when key_equal => cbuffer <= do_op; next_state := st_0C;
when kty_arith => acc <= do_op;
clr(cbuffer);
end case;
when others =>
fatal("Unknown case.");
end case;
state <= next_state;
end if;
end process;
end a1;
--- Calculator Testbench (Demo, not really a test.)
library ieee;
use Std_DevelopersKit.Std_IOpak.all;
entity calctb is end;
architecture a1 of calctb is
constant prec : integer:= 30;
signal display : std_logic_vector ( prec-1 downto 0 );
signal key : key_t;
signal clk, reset, beep : std_logic:= '0';
begin
c:entity work.calc(a1)
generic map (prec)
port map (display,beep,key,reset,clk);
clk <= not clk after 2 ns;
process(beep)
begin
if beep = '1' then
report "Beep starting.";
elsif beep = '0' then
report "Beep finished.";
end if;
end process;
process
variable initialized: integer:= 0;
type key_array_t is array ( character'low to character'high ) of key_t;
variable to_key: key_array_t;
procedure command (constant cmd: in string) is
variable c: character;
begin
if initialized /= 1 then
for i in to_key'range loop to_key(i) := key_never; end loop;
for i in 0 to 9 loop
to_key( character'val((i+character'pos('0'))) ) :=
key_t(std_logic_vector(key_0) + i);
end loop;
to_key('+'):= key_plus;
to_key('-'):= key_minus;
to_key('/'):= key_divide;
to_key('*'):= key_times;
to_key('='):= key_equal;
to_key('c'):= key_clear;
to_key(' '):= key_none;
to_key(character'val(0)):= key_none;
initialized:= 1;
end if;
for i in cmd'range loop
c:= cmd(i);
key <= to_key( c );
assert key /= key_never
report "Demo error: illegal key in command: " & to_string© & c
severity failure;
assert key = key_none
report "Key " & c & " Display " & to_string(to_integer(display))
severity note;
key <= key_none;
end loop;
end procedure;
begin
reset <= '0';
for i in 0 to 1 loop wait until falling_edge(clk); end loop;
reset <= '1';
reset <= '0';
command("c 5 c 12 + 34 = ");
command(" 1 + 2 + 3 ++ 4 = - 10 = ");
assert false
report "Done with tests"
severity failure;
end process;
end a1;
۰۴-بهمن-۱۳۸۹, ۰۰:۵۲:۵۹ |
موضوعات مرتبط با این موضوع... |
موضوع |
نویسنده |
پاسخ |
بازدید |
آخرین ارسال |
[پروژه] مثال های FPGA درس معماری کامپیوتر |
aKaReZa75 |
6 |
3,157 |
۲۶-بهمن-۱۳۹۷, ۱۱:۴۱:۱۷
پروژه های FPGA |
1nafar |
2 |
10,369 |
۲۰-خرداد-۱۳۹۵, ۱۱:۰۸:۱۰
آخرین ارسال: mahdiakbari000
[آموزشی] بورد آموزشی fpga (اسپارتان 6)همراه با آموزش های کامل فارسی |
firetooth |
4 |
6,549 |
۲۶-مرداد-۱۳۹۴, ۱۰:۵۶:۴۸
آخرین ارسال: firetooth
دریافت کتب آموزشی FPGA |
WhiteNoise |
20 |
40,561 |
۲۰-مرداد-۱۳۹۴, ۰۰:۵۴:۰۹
آخرین ارسال: salehjg
اتصال usb به fpga |
salmon |
4 |
4,593 |
۰۸-فروردین-۱۳۹۴, ۲۲:۴۲:۳۹
آخرین ارسال: salmon
سوال در مورد پیاده سازی fpga |
khoshchehre13 |
1 |
2,258 |
۰۶-اسفند-۱۳۹۳, ۲۰:۵۵:۳۴
آخرین ارسال: khoshchehre13
نرم افزار هاي FPGA |
sharin |
1 |
5,078 |
۰۲-آذر-۱۳۹۲, ۲۳:۱۲:۲۵
آخرین ارسال: microoo
FPGA به چه دردي مي خوره؟ |
ha_60 |
57 |
45,210 |
۲۸-شهریور-۱۳۹۲, ۲۳:۲۵:۲۷
آخرین ارسال: saeed_a_1990
[سوال] fpga advantage?? |
farshad1195 |
1 |
2,856 |
۲۵-اردیبهشت-۱۳۹۲, ۰۰:۵۸:۰۹
بازار کار FPGA |
the_fallen |
7 |
12,968 |
۲۳-بهمن-۱۳۹۱, ۱۴:۵۸:۱۲
آخرین ارسال: abbasalifix
